C3 Body Alignment - NCRS Discussion Boards
C3 Body Alignment
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 Body Alignment
    Art The inter fenders control the hood heigth and is an area where you can cut the fender off at the top only and make adjustments and rebond. I used a cut off wheel.I did this on the inside of the fender at the lower edge so from under the hood you can't see the repair and even under the fender in that location the fix is not to be seen if you work at it in the radius and bond seam. Lyle
    Lyle
    • Harmon C.
      • August 31, 1994
      • 3228
      Lyle
