After fighting the u-joints for a couple of days, I found a way to find what was wrong and fix it.
Three joints went in with no problem. The fourth went in the halfshaft with no problem but wouldn't work in the flange.
I took it out and reinstalled about 5 times but each time it was so tight, it would barely turn and when it did turn, it was notchy. Even removing the clips and loosening the caps did not let it turn freely.
The flange was bolted to the spindle flange during installation so the flange wouldn't bend, but I suspected it had been bent before.
Finally, I took a Craftsman 7/8 deepwell 1/2 drive socket and slid in one end and through to the other. I discovered that the holes were cocked so that they were at least an 1/8 inch off. But what I didn't expect was that they were not bent inward, like you expect, but outward and to the side.
After pulling, bending, pressing, and hammering, the holes finally lined up and the joint went in.
But without using the socket to see where the holes lined up, I'd still be out there trying to get that one in.
The 7/8 worked well because it was very snug. It had to be tapped in and out. As such, it showed burrs in the edges that I didn't see and was tight enough to indicate how far off center was on the other end.
Your socket size may vary.
