I had a shop put on one of these new power steering kits, and they used the rear hole at the spindle. My 67 service manual says that the forward (fast ratio) hole should be used with power steering with a warning of interference if the rear hole is used.
What would be the difference in handling if the rear hole were used, versus the front hole, and what interference are they talking about in the service manual.
The power steering is great for parking although a little to sensitive at higher speeds. Is there any way to adjust things to get a little more feel of the road at higher speeds. Maybe it is the hole position, although using the front hole, I think would make it more sensitive.
Jerry Fuccillo
Jerry Fuccillo
