I just recently installed a front engine wiring harness which includes wiring for the headlights and parking lights at least up to the connection leading into the headlight buckets and parking lamp housing. The harness was obtained from Lectric Limited. The installation was easy and straight forward (not for my hands and arms at least). Everything works fine and maybe even a little bit better, however, my headlights (high and low beams) and parking lamps do not work. Turn signals, tail and brake lights work okay. I have also replaced the headlight switch and wiring harness that goes into the headlight buckets. I still have no headlights or parking lights. They worked prior to the harness change.
It's time to stop creating new words. Any suggestions would be appreciated. Thanks.
