I presently have the engine and trans out of the car, after cleaning things up a bit, I have noticed quite a large weld repair in my aluminum bellhousing, near the starter mount area. I would rather have a scattershield any way, for safety and damage due to a grenaded clutch assy, I know this is rare, but it does happen.
I have seen the Lakewood model in Jegs, and I am sure there are more models out there, is one better than another, will there be any problem mounting the starter, fork lever and throwout bearing assy,tranny and shifter mounting dimensions, or anything else...if a good one can be recommended with no problems , I would be very interested, if not , I guess I will just stay with the aluminum original.
Also, a few teeth on my flywheel are damaged, 2 are actually missing the outside third of the tooth, should I resurface and re-use this flywheel or consider a replacement aftermarket type, 30lb steel I assume....It did work fine before i took everything out.
