58 corvette fuel injection - NCRS Discussion Boards
  • David Magee
    I have recently purchased a car 63 nova that has the following.
    The car has a 7014900 corvette fuel injection unit on it they only made 504 of these does anybody have any idea what this is worth?
    The car also has a complete late production 3789935 61 corvette motor anybody know what that is worth?
    It also has a 1111064 distributor 64 corvette fi injection distributor.
    I am contenplating pulling all of this out of the nova for the right price. I will take $10,000 for everything.
    Dave
    215 669-5017
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 58 corvette fuel injection
    It's a No No to sell and give a price here !
    You should say , is their any one that know's some one that would need it.
    That statement would let people know what your intent is.
    • Ed Jennings
      A MINT fuel injection, complete with adapter plate and correct distributer is worth around $6K. The correct air cleaner will cost another $1000 or so. Mint means it looks and runs just like it left the factory, no modifications (other than a fuel shut-off solenoid) and no mismatched parts. Units needing cosmetic/mechanical restoration, or put together out of parts are trading for a lot less.
      • Tom P.
        • April 1, 1980
        • 1814
        I guess that means my 7011956 FI unit, Serial # 1001 with an 1111070 dist isn't worth much then. Right?
        Although it sure does run great on the SB400 in my 56!
        • Mike B.
          • November 1, 2004
          • 389
          Dave,
          I am search of the original block for my late model '61 Corvette. Can you provide the numbers/letters from the front right-hand pad? I am ever hopeful that it will turn up someday. Even if it does not match, I might still be interested in the engine if the date code is correct (cast on top right on the rear of the block). Can you provide that info too?
          Mike
          • Ed Jennings
            No, Tom, I wouldn't say that. However, DeGregory, Podell, et al, sell restored units with all the right parts for around $6K. DeGregory's units are complete down to the right bolts and gaskets for installation. Units that need restoration/rebuild or are missing parts aren't going to be worth as much to most folks. Since your unit is on the 56, you don't have to give a hoot if there is a mismatch of parts as long as it runs well.
