Re: Rear Axle - NCRS Discussion Boards
Re: Rear Axle
  • Mark Hedberg
    Re: Rear Axle
    Thanks, Joe. Is the bottom surface of the main carrier housing also where the codes reflecting the drive ratio are located?
    Re: Rear Axle
    Mark----
    Yes, that's the "code" that I was referring to. It is found in the same location as the date code. It is a 2 or 3 character alpha code(depending on year).
