C2 - C3 carpet question / C3 door pnl screws - NCRS Discussion Boards
  • Zachary K.
    • March 1, 1986
    • 162
    Carpet question Convertible's only C2 and C3:
    Have searched through the AIM and can't find anything on how the rear bulkhead
    carpet ends are laid out and cut. Anyone with an original car and carpet that can post a digital picture of the correct layout and cuts of the carpet around the rear deck spring housings. I am looking to see also if the midyears and late models (68 - 74)convertible capret folds and cuts were done the same way.
    Inner Door Panel question C3's:
    I'm looking for the correct type of door panel screws that were used at the upper front and upper rear of 70's and 71's, these two screws went right through the door panels. The judging manual calls for a chrome, cross recess, oval head screw. In 70 seperate finishing washers are behind these screws, (it doesn't mention 71) but goes on to say, in 72 the finishing washer became part of the head of the screw. I'm not sure if it's flat or not. Anyone knowing that they have the original type of screws still in their door panels, I'd appreciate a picture of them or a better description of the washer with thickness and size.
    Thank you for your time.
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
