C1 guages - NCRS Discussion Boards
C1 guages
  • Bud Landacre
    C1 guages
    I have 2 questions regarding the speedometer & tach in my 62.
    1. The "guts" of the tach and speedo appear identical with the exception of the odometer mechanism in the speedo. Are they interchangeable?
    2. Is there a special tool or procedure for removing the needles from the shafts on these guages?
    Thanks in advance
    Bud Landacre
  • Ed Jennings
    Re: C1 guages
    I doubt the guts are actually interchangeable, but might be with recalibration. The tach needles will pull off, but I have always had to gently "unscrew" them a bit counterclockwise to get them off.Not sure on the speedo needle, never changed one.
    • Kevin Riel
      Speedo needle comes off the same... *NM*
