Decal Placements - NCRS Discussion Boards
Decal Placements
  • Snooz
    Decal Placements
    I need input on where to put decals on a standard suspension early 64 on the following? 1. Shock absorbers, front and rear, upper or lower section, inboard/outboard, distance from upper or lower mount. EK/EM label? Color? 2. Front Springs, ED, placed front/back/side and the number of coils from top or bottom? Color? 3. Does anyone know the correct labeling for the radiator and surge tank for an early 64, I am confused about placement of the green paper label, I'm ok on the foil, is there a inspection tag with the number 3 that goes on the radiator/and a inspection tag number 8 on the surge? Does the green label cover the part number/date code? Should there be a yellow rubber stamp with a CWT 10 mark?? What materials are the number 3 & 8 made of?
    Thank you!
    Lots of questions here....
    (1) Inspector's mark decals appearing on radiator and overflow
    tanks were adhesive backed green paper with black numerals
    available from many restoration parts catalog houses. Some
    controversy exists over '3' here '8' there and whether there
    were cases of '3' tags, double '8' tags, Etc. Think you'll
    find most NCRS judges cut slack on exact number as well as
    precise physical placement of these tags because folks were
    in a hurry back then and we see some variation in the few
    known original cars that have 'em intact.
    (2) On radiator, inspection tag was typically on the RH side,
    center of the radiator's upper. Would NOT be placed to
    obscure other radiator marks, stampings, Etc. But, would
    be rather hastily applied (cocked/skewed).
    (3) On expansion tank, I've seen the tag on the dated end of
    the tank both high and low, as well as on the side facing
    passenger compartment as well as on the inboard upper surface.
    In my book, it's a 'how do you feel' issue on physical placement.
    (4) On the CWT ink stamp, it was originally a white ink, but the
    underlying paint of the radiator was asphalt based (like frame)
    and with heat/cool cycles, paint and ink tended to migration
    mix over time appearing 'yellow' or off-white in hue. Rubber
    stamp as well as ink is an off-the-shelf item in the Long Island
    catalog. Take a few 'test' stamps before hitting your radiator.
    Tendency is for the ink they supply to transfer in a 'blotchy'
    manner while factory originals were nicely solid in consistency
    of white ink/paint uniformity.
    (5) On shock and spring sticker/label, there remains controversy
    over correct size/font of shock stickers. My guess is several
    versions were used over time and may have varied based on Delco
    producing plant location. Again, folks were in a hurry when these
    parts were produced and precise location of labels probably DID
    vary. Consult your NCRS Judging Guide as to what's considered
    'correct' placement and bear in mind, most judges are simply
    looking for the sticker/label to be present and readable as we
    know there WAS variance at the factory in terms of placement.
