1963 Ignition Switch - NCRS Discussion Boards
  • Dave S.
    • August 31, 1992
    • 2918
    Re: 1963 Ignition Switch
    Mike,
    I have the original tumbler(cylinder)as it has the proper key number stamped on it. I'm thinking that the replacement switch is different from the Delco #577 switch and does not allow the proper functioon. I'm hoping that if I insatll a Delco #577 switch the problem will be solved. Comments.?????
    • Peter L.
      • May 31, 1983
      • 1930
      The original '63-'64 Corvette ignition switch used in production was 1116635 (635 embossed on the switch). Parts History indicates it was changed to 1116650 in 07/66. Pete
