61 Tach Drive Generator - NCRS Discussion Boards
  • William Gallentine
    I purchased a Tach drive for my 61 and new gears for it, I believe I am missing somthing. What and how does the nylon gear fit in the tach drive?? What I have is just the flat gear with a hole in the middle. If you can please guide me as to where to find detailed info on this assembly.
    Thanks Bill
    Re: 61 Tach Drive Generator
    Bill -
    That plastic gear should have a shaft or axle through it; the front end of the shaft pilots in the front cover, and the rear end pilots in the rear cover and has a square hole in the end to drive the tach cable.
