I'm in the process of re-installing the rear spring on my 69' Coupe. I'm concerned regarding the length of the four 9/16" bolts that holds the spring to the rear cover- The original bolts I removed were 3 5/16" long and the replacements I purchased thru Muskegon Brake are 3 1/2". When I measure the center of the spring where it's compressed with the center bolt, I measure 2 3/8" (9 leaf spring). When I screw the 3 1/2" bolts and seat them in the front 2 holes with the spring plate in place (this is just a trial fitting, the spring is not installed), I get around 2 3/8" total before the lock washers are even compressed.
While the rear bolt holes go thru the cover and aren't an issue, I'm concerned that the front 2 will bottom out before it really makes full contact with the spring. With a the stories I've heard of broken covers and bolts puncturing the housing, I want to be REAL sure I do this correctly the first time.
I've already chased all the threads with a tap to make sure the bolts seat fully-
Has anyone run into this situation before? Do I grind down the 2 front bolts till I have 3 5/16"? Do I try to find 3 1/4" or 3 5/6" bolts for the front instead?
Any advice would be greatly appreciated.
Thanks!
Elm.
Thanks!
Elm.
