Silver cad plating - NCRS Discussion Boards
Silver cad plating
  • Jeremy Hedges
    Silver cad plating
    Anyone know where to get good silver cad plating done with decent turnaround?
    Jeremy Hedges
    #31711
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Silver cad plating
    Steve Gregario does good work and has good turnaround. Just had some done and have another batch ready to go. He advertises in the Driveline
    • Eugene B.
      • May 31, 1988
      • 710
      Steve,
      If you are speaking of Steve Gregori, you may want to check his website: www.brakeboosters.com. I believe his plater uses zinc; not cadmium.
      Jeremy,
      If you really want cadmium (not zinc), the members and myself can make recommendations. Just need to clarify what you really want.
      Gene
      • Clare Carpenter
        Contrary to popular belief cadmium plating is still widely used and readily available IF you know where to go. Due to costly EPA regs many smaller mom-pop type shops have stopped offering cadmium and the same goes for hobbyists. "Copy Cad" zinc plating kits like that offered by CASWELL may duplicate the look of cadmium closely but not its inherent properties.
        Cadmium plating is a sacrificial coating and offers superior protection against corrosion over zinc, especially in marine and tropic conditons. It also has better lubricity, (sp) preventing galling between sliding metal surfaces and doesn't create residue when it "rusts" like zinc does. I believe that is why it was specified for latches, hood props, and other moving parts by GM over zinc which was/is widely used on fasteners.
        I believe that cadmium plating is the only approved method by the FAA for propellers and is also widely used in the military.
        Here are a couple of sources where you can get it done.
        Aero Propeller & Accessories, Inc.
        9616 Jeffco Airport Ave., Hangar 44
        Broomfield, CO 80021
        Phone 303-469-1749 or 800-525-8756
        Fax 303-465-1254
        J&L Plating
        21733 Dequinder
        Hazel Park, MI
        (313) 564-6143
        Both shops will take automotive restoration work and can do dichromate finishing as well.
          Plus, you can do it yourself...
          The 'chemistry' for electroplating cad is identical with that for doing zinc (tin too). Once you have a basic home system (both the packaged kits from Eastwood and Caswell get the job done), all you need to do is replace the zinc anode they supply with your own cad or tin anode and you're up and running! Don't have plating quality cad laying around? Contact me off board....
          • Chris S.
            • January 1, 2000
            • 1064
            Use Steve at Detail Plating as posted above
            Very good work
            I have use the at home kits with very poor results.
            Steve's work is very good
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
