c2 body weight coupe - NCRS Discussion Boards
  • Gerry G.
    • December 1, 2004
    • 35
    I want to build a body dolly and want to know how heavy duty the wheels need to be. I also would like to know were I can get a set of plans to build a dolly with out purchacing a vidieo, some one must have a set on the net.I want to use a chain fall to lift the body, I need to know the weight also to make sure upper floor of my garage will support it.Thank
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: c2 body weight coupe
    I have all the info you request. E-mail me for photos and plans. The body weighs under 600-700# empty. The important thing you need is HEADROOM in the garage. I lifted mine using the deck outside as my lift point. It worked fine as my garages enter under the deck. I also have a lift strap if you are interested....and a dolly if you live nearby.....
