73 454 needed will this block work - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    My 1973 car has D22 on the trim plate, so is that is Nov 22? therefore would this block work.
    Block #3999289 ( this seems to be the correct part number)
    D-3 72 ID (no idea what this means, I think it means april which makes it 8 months before my car was built.)
    Heads 3999241 (this seems to be the correct part number)
    cal
  • Mark #28455
    you can do better *NM*
    • Dick W.
      • 10483
      Re: 73 454 needed will this block work
      If you are going for originality, the eight mont spread is out of what NCTS uses as a normal window, which is six months. Actual spread is more like the ten days to four weeks. It can be a little closer, but remember the 454 was cast and assembled in Tonawanda and then shipped to St. Louis. You might see engines a day or two closer in cars, but I think that it would be pushing it.
      Dick Whittington
