1970 NA9 canister filter
  • Roberto L.
    • January 1, 1998
    • 523
    na canister filter roberto luis in the neverending engine compartment cleaning i took out the rochester canister in my california corvette with na option the top cover spring retainer and diaphragm is ok after cleaning but the filter in the bottom is missing what kind of filter is all my best from argentina roberto ncrs
    Roberto J Luis
    RMC
    1970 Corvette Stingray coupe MT 300 HP
  • Jack H.
    • April 1, 1990
    • 9893
    Re: 1970 NA9 canister filter
    re na canister filter jack humphrey hola roberto the filter is a circular cloth that slips in to prevent dirt dust accumulation they're still available at auto parts stores as this system was used for many years all across the gm car line cost is in the order of filter and it was then recommended to replace on oil change intervals if you want su agente es listo
    • Rolf Krueger
      re na canister filter rolf krueger fram makes the replacement gm canister filter it is available in many auto parts stores stateside
