C3 kickdown switch - NCRS Discussion Boards
C3 kickdown switch
  • Jeff A.
    • December 1, 2001
    • 95
    C3 kickdown switch
    On a 70, TH400 what colors are the wires on the kick down switch under the dash which is operated by the accelerator rod ? Does it make any difference which wire is connected to which terminal ? Thanks
  • KEN BUTCHER
    Re: C3 kickdown switch
    Hi Jeff, if I'm not mistaken there is an orange wire from the kick down to the transmisson and the other wire (black or brown) I forget the colour, and exactly where it's routed to in the engine compartment, since I don't have an automatic anymore.
    Maybe someone else can help you out.
    Ken.
    • KEN BUTCHER
      Hey Jeff, I was at the auto wreckers today and found a car with the kick down switch. The colours are (orange & pink). The pink wire is power, and the orange wire goes to the transmission. The female plug that attaches to the kick down switch I think goes on one way, but I don't think it matters. So that's what I saw today on my search and seizure adventure at the wreckers.
      • Jim T.
        • March 1, 1993
        • 5351
        Jeff just crawled from under my original owner 70's dash. Viewed two wires going to my kick down switch. Both wires fin into a plastic connector. The small black wire is the top wire and the large orange wire is on the bottom. The large orange wire could be confusing in that two large orange wires come through the firewall. The large orange wire with a small black stripe does not connect to the kick down.
