(Message Deleted by Poster) - NCRS Discussion Boards
  • Don 42616
  • Scott Marzahl
    Re: fiber glass repair
    A 2" hole isn't a difficult repair. I don't know what CC sells for a kit but you can pick up fiberglass mat resin and hardner and if you want it to look fairly original, black dye for the resin at any local marine supply or most hardware stores. Since the repair will want to sag while curing, you'll want to support it with a scrap piece of formica or cardboard covered with wax paper and duct tape it in place. You will want to grind (or use 36 grit sandpaper) the area out and bevel the edges of the hole several inches outward from the hole before laying down your wet glass mat. You can pick up a book explaining basic fiberglass repair at a book store or from the NCRS book store.
