C2 oil pan size - NCRS Discussion Boards
C2 oil pan size
  • Steve D.
    • February 1, 2002
    • 990
    C2 oil pan size
    63, 327 / 340
    How do you tell a 6 qt pan from a 5 qt pan? Catalog for power steering conversion says 340+ cars need to swap 6 qt pan for 5 qt pan and change dipstick. (Clearance problems I assume) My engine is not original and I don't know which pan I have. (The car is going to be a driver and the PS will allow my wife to enjoy the car also)
    Link to picture of pan in profile below.
    Steve
    Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2 oil pan size
    Steve,
    You are in luck. The Pan you have is the correct 5 qt. piece if you want Power Steering.
    tc
    • Steve D.
      • February 1, 2002
      • 990
      Re: C2 oil pan size
      Tracy
      Thanks. What are the distinguishing features?
      Steve
      • Craig S.
        • June 30, 1997
        • 2471
        Re: C2 oil pan size
        Steve - the lower portion of the sump area exetends forward more on the 6 quart pan, which blocks the area where the steering linkage needs to traverse...Craig
          Re: C2 oil pan size
          Steve----
          Also, there is no difference in the dipstick or dipstick tube for a 5 quart or a 6 quart oil pan; they are the same for both.
          • NANCY CHARLES
            Re: C2 oil pan size
            ON a 6 quart pan isn't 3 bolts to sump & 4 bolts to sump on 5 quart .what is length of the two sump base measurement ?
            • Brian Monticello
              Re: C2 oil pan size
              6qt
              • Harry Sadlock
                Re: C2 oil pan size
                Steve, the best I can recall, the sump, fron to back, on the smaller pan in 10.5 inches and the larger pan is 12 inches.
                Harry
                38513
                • Loren L.
                  • April 30, 1976
                  • 4104
                  From the back of the pan to the front lip
                  where is goes up is 14" + or -, depending on where you sighted from.
