lower radiator pipe 71 LS-5 Air - NCRS Discussion Boards
  • lyndon sharpton
    on the lower radiator coupling, as paragon calls it. which side does the lip go on? it goes to the pump side hose right? are does it go to the radiator side hose? how much clearnce is there from the tip of the fan blade, on most cars? it is tight on my car. my pipe is in need of replacment, so I am going to order one from paragon
