'66 TACHOMETER NOISE - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Just about anywhere above idle, the tach needle is a bit bouncy, accompanied by a low "gear turning" type noise. What might I check, or lubricate to try and solve the problem, and/or prevent what might come next? The tach cable is original.
  • mike mccagh
    Re: '66 TACHOMETER NOISE
    remove cable from its housing, clean it thouroughly, and then lubricate it( lightly) with delco speedo lubricant or vaseline(KY jelly if you are a dipstickeo). good luck, mike
    • Craig S.
      • June 30, 1997
      • 2471
      Mike - is the scented KY better Craig
      • Donald M.
        • December 1, 1984
        • 498
        If you live in northern climes, use the KY that warms up once applied to your..cable!
        Don
