I'm trying to determine the best way to remove the sliding door that covers the ash tray on my '66 4-speed console. Am I correct in thinking that the only way to remove the sliding door that covers the ash tray portal is to remove the frame on the underside of the console that the door edges slide in? Does anyone know if there is a way to unpeen the rivet-like studs that hold the frame to the console and to unpeen them in a way that allows one to repeen the studs after restoring the sliding door?
Secondly, what's the best way to remove the chrome tap on the top side of the sliding door that one pushes and pulls to open and shut the door. On the underside, it looks like there are two studs that are peened over, but there's also what looks like a squashed rivet head between the two studs. Is an entire sliding door with the tab attached available as an acceptable repro item?
Gary
Gary
