1971 air cleaner wing nut - NCRS Discussion Boards
  • Harold M.
    • September 30, 2000
    • 55
    I should know which wing nut is correct, but thought i would double check. One wing nut has a heavier metal and outside dimension from tip to tip is less and this one also is more narrow between wings.
    The second wing nut is wider and wing tips are further apart.
    Thanks in advance,
    Harold
  • Mike M.
    Director Region V
    • August 31, 1994
    • 1464
    Re: 1971 air cleaner wing nut
    "One picture is worth a thousand words"
    H. a. N. D.
