On my 61, when I pull the T handle up to shift to reverse the left side piece on the handle falls away from the handle. How is that piece fasten to the handle? Thanks for the help, Joe
C1 SHIFTER
Re: C1 SHIFTER
I've used a thin nail---peened the one end. It's below the shifter boot, so it's not visible. GM used a pin (I wouldn't call it a rivet)--just peened on each end. Vette Products of Lake Orion, MI, make the reproduction shifter assmblies, and I'm sure of yu talk to Mike Mahowski there, he can get you that pin.- Top
Re: C1 SHIFTER
There is no reverse cable. Inside the sheet metal housing is a pull down spring. Mine was broken in a couple places and the reversed lock out would not come off when shifting to first from reverse. had to bang the shifter to get it to drop out.
Vette products sells the spring also.- Top
