Steering Shaft Misalignment - NCRS Discussion Boards
  • Ben L.
    • May 31, 2004
    • 11
    I am using a replacement frame for my 65 convertible. The body has been mounted on the frame with no problems. I installed a rebuilt steering gearbox and new rag joint. When reinstalling the steering column, I was shocked to see that the steering shaft is misaligned by about 1/2" with the splined hole in the rag joint. Can the steering box be shimmed outward to correct this? Any other suggestions?
  • mike mccagh
    Re: Steering Shaft Misalignment
    1/2" excessive. take frame to body shop with frame machine and have them check alignment specs. new frame may be bent. mike
      Ben-----
      It could be shimmed, but said procedure was never used or necessary in PRODUCTION and I've never seen it required in SERVICE. As Mike mentioned, I think that I would suspect some problem with the frame.
      • Mike Nelson
        And make sure the steering column is totally free and not tightened down anywhere. The clamp on the firewall can be moved a little to compensate, but probably not 1/2".
        • Mike McKown
          Can you loosen the body on the frame and shift it enough to gain anything in a positive direction?
          • Rob A.
            • December 1, 1991
            • 2126
            Ben,
            When disassembled my '67 I found one "U" shaped, thick shim between the steering gear box and the frame, held in place by one of the bolts. I replaced it when assembling the car. Could yours have had a shim that you haven't replaced?
            • Ben L.
              • May 31, 2004
              • 11
              The only way that I could align the shaft with the rag joint was to loosen the steering box and shift it inward. I will shim it in this position just long enough to get the car to a shop that can evaluate the problem. Thanks for the input. Ben
