Does anyone know where I can find the dimensions of the power switch cut out which is located under the dash pad behind the courtesy lite?
C1 power top switch cut out
Re: C1 power top switch cut out
Ray - As Mike said, there is a hole in the bottom of the dash structure just forward of the courtesy light. Remove the courtesy light and you should be able to feel it by running a finger along that direction. Depending on how much padding there is in the bottom fo your dash pad, you shoud also be able to press and feel the cutout in the dash structure.- Top
Ray,
The switch is located 2 and 1/4 inches from the fiber glass (not the trim) and 1 inch from the courtesy light centered from left to right. If you are putting a power top together I know the system very well. Fill free to contact me. My car is a 59.
Good luck, Jimmy- Top
