C2 Instrument panel Codes/Numbers - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    I have the instrument panel out of my '66 427/425hp car today. I want to verify that the panel is correct. It has a "LB" code and a Cluster number of: 6457984.
    Is this correct for a 80lb oil gauge and a high rpm tachometer? The date looks like: "OCT 15 65064"
    Thanks for the help.
  • Mark L.
    • 550
    Re: C2 Instrument panel Codes/Numbers
    Ken, From the research that I've done and the knowledge of the IP in my 66 I believe the LB is correct for a 425 hp engine option.
