As per suggestions made earlier here:
To address 5,200 rpm hi-rev problem, I installed the hi performance rotor from Accell.
Better results:
Obtained another 1,000 rpm...From 5,200 to a higher 6,200.
But, the car still has hi-rev issue at 6,200, and stops pulling with a mild backfire out the exhaust.
I cannot trust former mechanic. It's questionable if he EVER actually installed the TI amplifier upgraded circuit board purchased from TI Speciaties.
The same mechanic installed (AC delco?) service replacement rotor and cap.
Questions:
Could the NOT correct service replacement cap might be an issue?
Who sells correct Delco Remy replacement distributor caps?
Could the TI amplifier be contributing to rev limit?
The wires looked fine.
Better results:
Questions:
