OK. GM serpentine belt conversion. Included GM info indicates this system based on the early TPI systems of the early '90's. Suggests reference '91/'92 Camero or Firebird Service Manuals for more detailed info.
Cut to the chase: Alternator: CS 130 series, PN 10463172, AC Delco PN 321-464, 105 amp reman unit.
Has one big +Bat lug which I think I understand. Then I get confused. There is a 4 wire plug in to the alternator. All white wire insulation. One wire is bigger than the other 3 which are all the same small size (maybe 18/20 gauge). So, may I assume this baby needs a VR, and if so, part #? And, if so, how do I hook it up with 4 wires all having the same color conductor?
I did check my 92 454 SS. It has the major batt lug and a big plug-in going into the alt, but only one wire is going in and it is quite small.
HELP... Thanks, Dennis
