I am in the process of removing the body from the frame and the two rear body mount bolts won't come out because the nut is turning on the inside pocket below where the rear deck hinges are. I would like to remove the hinges so I can get at the body mount bolt. The bottom bolt is no problem on the hinge but the top two bolts seem next to impossible to get at. Any tricks to this would be greatly appreciated.
Thanks Sheldon
Thanks Sheldon
