C2_#3 body mount question - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    63 convertible
    When I dug the old putty/sealer out of the #3 mount area, I found spaces on three sides; left, right and rear. (The left space is visible in the picture below) Is this normal?
    The rear space is visible from under the body and is filled with a sealer from the bottom side. The right and left spaces are not visible from below.
    Steve
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2_#3 body mount question
    Steve,
    No, those are perforations due to corrosion. It doesn'look very bad, though. Clean/grind the area as best you can and paint with fresh zinc chromate primer. Generously slather the whole area inside and outside, with a good silicone based caulk.
    Joe
