1967 Turn & Hazard Flashers - NCRS Discussion Boards
  • Rick S.
    • January 1, 2003
    • 1203
    I have finally gotten around to checking my turn and hazard flashers and would like to know if they are correct. The Judging Manual states both are non-DOT and I do not see any letters "DOT". Would there be any numbers along with "DOT"? On the yellow plastic turn signal flasher top half it is imprinted "TUNG-SOL 323, 3 lamp 12 volt". The bottom half is imprinted "SAE J590?, USA PAT.RE24023 FLASHER". It has a wax paper capacitor. The hazard flasher is round, natural aluminum. The top half is imprinted "Made in USA, 552-12v". In the center is "TS". The bottom half is imprinted "SAE J945, PAT NO. RE 24023". Do these 2 flashers sound correct for a 1967? I have seen several hazard flashers on E-bay that are rectangular, not round like I have in the fuse panel and this is my cause for concern. Thanks in advance. Rick
  • Rick S.
    • January 1, 2003
    • 1203
    Re: 1967 Turn & Hazard Flashers-Addendum
    I should correct my original post to state that the wording is embossed not imprinted.
    • Kevin M.
      • November 1, 2000
      • 1271
      Those sound right to me, and you have the wax paper capacitor to boot.
      Kevin
      • Peter L.
        • May 31, 1983
        • 1930
        Rick - I agree with Kevin that they sound correct; but want to add that the T/S 552 configuration you describe is what I would expect to see on '67s build in calendar year 1967 because the T/S 552 flasher manufactured thru calendar year 1966 were silk screened around the side of the cover and were not embossed on the top. Pete
        • Rick S.
          • January 1, 2003
          • 1203
          Kevin & Pete,
          Thanks for your replies. Pete, my car is a June 67 build car. I happened to see both styles on E-bay, embossed and silk screened on the side and thats what got me to thinking if I had the correct one. Thanks again, Rick
