1966 odometer/tripometer - NCRS Discussion Boards
  • Dennis B.
    • May 31, 2004
    • 174
    My odometer and tripometer stopped working this week while the speedometer continues to work fine. I assume this all works off the same cable. Where am I looking to repair this. I assume I will have to pull the guage cluster.
  • Harry Sadlock
    Re: 1966 odometer/tripometer
    Dennis, yes, pull the cluster. You can probably the fix the problem yourself, you just need to determine where the problem is. It's normally a worn gear. If you want to send it out, there are a number of shops that can do this for you. Check the archives. You will see positive and negative comments on almost all of them.
    Also check the archives on methods to pull the cluster.
    If you have other problems, consider fixing them all at the same time. Such as dim bulbs/lamps, amp gage does not read correctly. (this is the time to pull the amp gage and tune it to a sending unit). Or even have the entire cluser restored.
    Harry
