66 SB Hood support left side with AC - NCRS Discussion Boards
  • Daniel C.
    • September 30, 2005
    • 31
  • frank clark
    Re: 66 SB Hood support left side with AC
    Dan,
    I have a 66 w/ac as well. My car does not have the sheet metal bracket. My guess it was added to repair some damage. What serial number is your car? I can send a picture of my hood if you want to compare.
    Take care,
    Frank
    • Daniel C.
      • 31
      Frank, 194676S117402, Picture would be helpfull. Thanks,Danny
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1464
        Noland's book has a clear picture and exlpanation.
        The hoods inside framing has a slot cut into it, as yours seems to, to add a
        reinforcement plate for the bolts to pass through the support, then the fiberglas, then the plate, to be nutted on the inside of the channel. No external metal piece.
        H. a. N. D.
        • frank clark
          Here are two pics of my hood. The work that looks like I would do in my back yard is the hole cut for the hardware in the side of the hood re inforcement which is rough.
          Frank
          • Daniel C.
            • 31
            Thanks Frank, I think I am going to remove my sheet metal bracket, and I bet I'll find some broken glass.
