67 starter and fuel pump bolt markings - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    I have searched the archives and can not find the correct head markings for the starter to block mounting bolts and the mounting bolts for the fuel pump for a small block. Can anyone help? Thank you.
  • Kent K.
    • December 1, 1982
    • 1139
    Re: 67 starter and fuel pump bolt markings
    Randy ---- My records from my '67 327/300 A/C 4-speed Corvette are as follows:
    Starter Motor:
    Outboard bolt is 3/8" - 15 x 1 1/4" w/ 5/8" threads (6 radiating rays from small center circle)
    Inboard bolt is 3/8" - 16 x 4 or 5" w/ 3/4" tgreads (same head marking)
    Fuel Pump bolts are 3/8" x 1 1/8" course thread (grade 5 RSC, R or NAT)
    My records do not indicate finishes for these bolts. Someone else may be able to provide it and/or additional information.
    Hope this helps.
    Kent #6201
    Kent
    NCM Founder - Member #718
    • Michael H.
      • January 29, 2008
      • 7477
      Randy,
      Not 100% sure on the starter mounting bolts but I believe they are a dull cad or zinc.
      The fuel pump bolts are dull cad or zinc (for small block) also and have a very unique head design. It's a washer head plus a lose/attached lock washer and is an odd 7/16" wrench size. Has RSC head logo, among others, as Kent mentioned. I can post a scan if you would like to see one.
