carb body re -color - NCRS Discussion Boards
carb body re -color
  • lyndon sharpton
    carb body re -color
    who does the best re-color on the carbs? any one know of a shop that will do a job that looks OEM. some of the carbs that I have seen look to dark, then some look to gold. In your opinion whos is dead on OEM?
  • Clem Z.
    • January 1, 2006
    • 9427
    no 2 new ones even look the same
    and i would guess holley recondition center would come the closest.
    • lyndon sharpton
      Re: no 2 new ones even look the same
      you know what they get for a color restoration? at the holley shop?
      • Clem Z.
        • January 1, 2006
        • 9427
        no i do not,try 1-866-GOHOLLEY but
        you were talking about a Q jet were you not?. i know they restore Q jets also
        • lyndon sharpton
          Re: no i do not,try 1-866-GOHOLLEY but
          yes Q-jets the one an only.
          • Steve Antonucci
            Re: carb body re -color
            Lyndon,
            I have used Custom Rebuilt Carburetors to do all of my carbs., including
            Rochester 4bbls, Holley 4bbls & Holley tri-powers. Phil Cancilla does a
            great job of dialing the color in. I have a NOS ( from back in the day )
            1969 427-390hp Rochester carb that I gave to Phil Cancilla to use as a
            color guide. When he returned my 7029215 carb ( restored ), it very closely
            matched the NOS carb I lent Phil.
            I don't think you will be unhappy with his work. Just make sure you
            communicate to him that you are particular on the color.
            You can reach Phil: thecarburetorman@aol.com
            Good luck !
            Steve
            • Harmon C.
              • August 31, 1994
              • 3228
              Carb resto cost. and much more
              lyndon
              Nothing in this hobby is cheap and when you are done you will be upside down to show a profit. Take a vette to a regional 500 miles away for judging and get by for lees than $1000. is hard for me to do. Then you need a truck and a trailor or pay $1.00 per mile to have it hauled it all adds up. One needs to enjoy it to make it fun.
              Lyle
              Lyle
                • 11608
                Re: Carb resto cost. and much more
                I'd talk to Gerard Fuccillo about how he did his, and consider doing it myself if the only thing you need is a coloring.
                Allegedly (per Chicago Corvette who sold it to me) Holley rebuilt my Q-jet. Whomever did it did a horrible job. As a result I'd never send a Q-jet to Holley just in case they really were the ones who did it.
                If you don't mind waiting a year, there's always Jerry Luck.
                Patrick
                • lyndon sharpton
                  A Truck an a Trailer? oh my car drives just fine, it is not borke.
                  • Bryan L.
                    • June 30, 1998
                    • 397
                    A year for JL? That's optimistic Doc.
                    BL
                    • lyndon sharpton
                      you say that Holley rebuilt your carb? can you go into detail why you were not happy with your carb? was it a cosmetic, are was it performance problem?
                      • Harmon C.
                        • August 31, 1994
                        • 3228
                        My truck pulling the trailor uses less fuel than my big block. It's still not cheap. If you find a good carb man good luck. I spent $1000. on the same carb with 4 rebuilders over a two year period and it was still a piece of junk. In about 8 hours and a tank of gas I fixed it.Twice when I got it back and took the vette for a ride the engine was covered with overflowing gas. It's a wonder it didn't burn up.That was ten years ago and I have just rebuilt them myself with less problems. One of the vendors has been named in this thread and I won't tell which one as maybe mine was the only bad one he ever did.
                        Lyle
                        Lyle
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          the old holleys were build and rebuild
                          with cork gaskets which dried out and leaked. also the surfaces get warped and unless you machine them or press them flat you will have a leak.
                            • 11608
                            See Lyle's post below. My experience was similar. Check the archives for the words "expensive doorstop" and you'll find threads on my carb.
                            Chicago Corvette "told me" that they had Holley rebuild my carb for me. There was no box or receipt from Holley as it left CC, went to the rebuilder, came back to them and shipped to me. Whether or not CC lied (and they easily could have) I don't know. But, if they were not lying, I'd never use Holley for a Q-jet.
                            If not Luck, I'd consider customrebuiltcarbs.com or Brad Urbin's Carburetor Shop 8460 Red Oak St. Rancho Cucamonga, CA 91730
                            Patrick
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              i never said the rebuild would be good
                              just the color should be correct. i have heard that for some reason they cut off the power piston stop,i do not know if that is true but that would be a no,no
