metering rods - NCRS Discussion Boards
metering rods
  • Roy B.
    • February 1, 1975
    • 7044
    metering rods
    For newbees may help
  • Roy B.
    • February 1, 1975
    • 7044
    Re:235 engine
    The real original vacuum had a nut on the front so that the spring could be changed , where as the replacement din' t 53 to 54 Corvette.
    • Doug Flaten
      Re: metering rods
      Do you know if the metering rods from the AFB's fit the WCFB's?
      The reason I ask is that a selection of rods and jets are readily available for the AFB's, but I did not know if they will work.
      Doug
      • Clem Z.
        • January 1, 2006
        • 9427
        NO they are not the same *NM*
        • Doug Flaten
          Re: NO they are not the same
          Thank you Clem.
          Doug
          • Joseph T.
            • April 30, 1976
            • 2074
            Lots of Chrysler/Plymouth WCFB's around..might be a good source to find different size metering rods.
            I used to have a 57 Plymouth Fury dual quad set up..that came from an old hot rodder..he said they did not have the same flooding problem?
            I would guess there is a metering rod parts book somewhere..I would like to see it if anyone has one.
            Joe
            • Roy B.
              • February 1, 1975
              • 7044
              Re: metering rods
              WCFB was used in many other years and make cars, At swap meets you find many , I buy junk looking ones from 5 to $15 dollars just to collect their metering rods.The parts dept. Used to sell KITS having many rods of different sizes , with them you dint need to open the Carb to replace them , so that there was no need to buy jets which would cause you to open up the Carb to replace.
              With the kits you could fine tune your Carb to meet your condition.
