sunvisors - NCRS Discussion Boards
sunvisors
  • John O.
    • May 31, 1998
    • 480
    sunvisors
    Hi All
    I have a new pair of Sunvisors for my 62 vette with no hardware installed. I have the hardware and needed to know if there is some special technique to install the hardware.How close to the edge do I put the hardware and whats the best way to make the holes.
    Thanks....John
  • Nicholas L.
    • November 1, 1982
    • 340
    Re: sunvisors
    When I did my sunvisors I drilled them but the padding inside the visor started to wrap around the drill. Pucnching a hole may be better.
    • John O.
      • May 31, 1998
      • 480
      Re: sunvisors
      Thanks Nick. I was thinking about drilling but afraid of the material wrapping around the bit just like you said. So I will just use an awl and pierce the holes.
      Thanks......John
