Need rubber spacers between leafs - NCRS Discussion Boards
  • Frank P.
    • April 1, 2005
    • 30
    took the rear leaf spring apart to paint correct gray, now need correct rubber spacers that fit between each leaf....as always, thanks in advance! Frank
  • Alan Drake
    Re: Need rubber spacers between leafs
    Hi,
    Try Quarta 28-05A @ $65 or Bairs 5263rk @ $52 and there are others.
    Both of these are the kits - liners, bolt, end washers, and paint.
    Bairs has spray can while I believe Quarta has paint in a can (check this)
    I purchased from Bairs but then wanted the paint in the can to redo as origninal. Quarta had the original Ionokald which I plan to SLOP on the springs.
    Corvette Restorer has article on restoration and do a search on rear leaf spring since excellent info has been posted.
    Take some pictures to document the old spring since a member will be asking for them for an article he is doing.
    Have fun
    • Alan Drake
      See Suspension Help 1/25 below *NM* *NM*
      • Frank P.
        • April 1, 2005
        • 30
        Thanks Alan...shoulda kept looking in the catalog..got as far as the paint and ordered that...very much appreciated..got the kit on its way!
