Next month, I'm pulling my L46 out of my '70 and want to rebuilt it to as close to stock as possible. (108k miles and smoking!) I figure it will probably need boring and maybe a crankshaft bearing grind at the machine shop, but other than that, I want it put back together with stock specifications.
Where can I find the camshaft specs for an L46?
More importantly, can you recommend a source for OEM or OEM style engine parts?
I'm going to need pistons, bearings, cam, timing chain, oil pump, gaskets, oil pump, etc...
Thanks - Mark
Thanks - Mark
