old stock, think that that is all that is available. You may want to contact Lopers, PAW, or Summit and check if they have anything still sitting on their shelves, but I think it may be futile.
Unless Uncle Joe can hunt down some.....
One more thing.....
you can buy the individual gaskets needed withoub buying the whole kit. Power valves & needle & seats can be purchased as seperate items. The meterring plate gaskets on all Holleys are interchangeable, same with the metering block gaskets, and fuel bowl gaskets. If you get the individual gaskets, buy the blue ones, as they are permanent, and can be re-used over nad over. If your friend is looking for originality, then those won't cut the mustard.- Top
