Re: Standard and Borg Warner numbers - NCRS Discussion Boards
  • motorman
    the GM cans have the last 3 numbers of the part number plus the number of degrees of advance built into the can. you can also match the number of degrees by checking the distance between the vertical pin and the end of the slot next to the can with a pair of vernier calipers as this is the stop for the advance. just look for a can with the same distance.
