Rivet setting tools - NCRS Discussion Boards
Rivet setting tools
  • Steve D.
    • February 1, 2002
    • 990
    Rivet setting tools
    The following are some notes I received from Chuck Arnold re: rivet setting tools available from Brown Aviation tools (WWW.browntool.com). Good info to share.
    "I got their part number 1002-16 for 3/16 rivets but it proved to be a little wide. I would order either a 1002-6 1/8" or 1002-11 in 5/32". You might also consider some of their offset setting tools to get in tight places. Be sure and get their plastic rivet caps to protect your parts.
    I didn't and have a few scratches in the powder coat. They are part numbers 1003-1006 depending on the size of rivet setting tools you get.
    When you rivet set your hammer around 45lbs. and it works a little slower but you will not mess up your parts."
    Steve
  • John M.
    • January 1, 1999
    • 1553
    Re: Rivet setting tools
    Here is another good link for rivet setting tools. I have been buying from these guys for over 30 years. They allways have surplus aircraft tools at a bargain price.
    http://www.yardstore.com/index.cfm?A...y&Category=107
    Regards, John McGraw
    • mike mccagh
      good tool source, john. good seeing you in fla. regards, mike
        I buy mine from www.aircraft-tool.com, and find that about 15 psi at the air hammer works fine; I use a mini-regulator at the tool.
