As I indicated in an earlier thread about my having to bite the bullet and pull my trans again to see why I have a chatter problem, I did so today and found some interesting things. I would like some advice from those with experience.
My car is a 67 small block, and I installed a new LUK rep set clutch assy last November. Flywheel was resurfaced. From the start I had a light chatter on low speed engagement that wouldn't go away. Advice from this forum and from LUK was to pull trans and check runout of flywheel.
Upon removal of clutch pressure plate, I observed that the pilot bearing was loose in the crank - came out by hand and spins freely in the crank!! It didn't go in that way for sure, in fact I had trouble driving it in. This bearing came with the LUK kit, and was not magnetic (I checked it). The original pilot bearing that I removed prior to installing the Luk kit in November had to be pulled out with a puller as is normal, and wasn't excessively worn either. I went ahead and installed the new one that came with the Luk kit since I had it.
Flywheel and pressure plate both look pretty good (however they were only installed a couple of months and maybe a hundred miles or so). I can tell however that there is some minor spotting on the flywheel, probably indicating some uneven engagement. I checked runout and it is about .003" best I can tell using a dial guage. How much runout in a flywheel is too much?
By the way, I did NOT get the flywheel and/or clutch assy balanced last November thinking that it wasn't necessary, but now maybe I should...
Advice?
Advice?
