'67 Wheel Weights... - NCRS Discussion Boards
  • Patrick T.
    • September 30, 1999
    • 1286
    Although the latest edition of the '67 Judging Manual does not mention any particular logo on the inside wheel balancing weights, I've heard that it should say "Micro", which is debossed on the "correct" weight's and labeled in ounce's.
    Can someone verify this for me? Thanks, PT
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: '67 Wheel Weights...
    I believe there was an article in the RESTORER last spring on the subject. Check it out.
    • Gary B.
      • February 1, 1997
      • 6979
      Wheel Weights; read the Restorer article
      Patrick,
      Read my article in the Restrorer or borrow that issue from a fellow NCRS member if you don't have it. I can't remember which issue it was, but it was within the past 1.5 years. There are several logos that are correct for mid-year cars, but best to read the article to get the details. Unfortuantely, I do not know of a source for any NOS or vintage weights, so you'll have to roam the junk yards to find some.
      Gary
      • Patrick T.
        • 1286
        Re: Wheel Weights; read the Restorer article
        Thanks Steve and Gary, Paragon sells the wheel weights in their catalog, which states are correct and have the Micro logo on them. They say that's what the Judges are looking for. Wouldn't you know it, I just took off my rear tires and looked at the weights and they say Micro as well and I got them mounted at a tire shop four years ago. PT
        • Gary B.
          • February 1, 1997
          • 6979
          Patrick,
          You need more than just the MICRO name. Micro weights over 1/2 oz need to have the weight designation appear twice, both times in ounces, once on each side of the word MICRO. Most modern Micro weights have the metric weight on one side of the MICRO. So, you need to see what the Paragon weights look like. If you got new MICRO weight 4 years ago, I bet they have the metric weight embossed on them, which is a no-no for '67. Note that you cannot simply grind off the metric weight since that will leave you with a weight with only the designation on one side of the MICRO. My article explains everything in much detail. Find out what Paragon is selling and let us know.
          Gary
          • Patrick T.
            • 1286
            Gary, here is what they look like. The weights on my wheels are identical. Thanks, PT
            • Gary B.
              • February 1, 1997
              • 6979
              Can you help me with the numbers?
              Patrick,
              In your photo the weight at the bottom shows the typical problem: 2.0 oz = 57 grams. This weight should get a deduct on a mid-year since it doesn't have the 2.0 embossed on both the left and right.
              I can't quite read the numbers on the top weight. Are they 25 or 2.5 on the left? And 3.5 on the right? Makes no sense to me.
              Gary
              • Patrick T.
                • 1286
                Re: Can you help me with the numbers?
                Gary, the weight in the bottom of the picture is 2 oz. The one at the top is 1.25 oz. The weight on my wheel says....2.5 MICRO 78. That's all I can make out. PT
                __________________________________________________ _____________________________
                • Gary B.
                  • February 1, 1997
                  • 6979
                  Now, the number make sense.
                  Patrick,
                  Now the numbers make sense (sort of), with 1.25 oz = 35 grams. With your 2.5 oz weight, the metric equivalent should be 70.875 or 70.9, or 71, but not 78. In any case, none of these weights will pass muster with any informed NCRS judge.
                  So, Paragon simply is selling some newer MICRO weights, but their statement that the judges are looking for the MICRO logo is misleading in several ways. First of all, there were at least 4 other suppliers, so MICRO is not the only acceptable weight, and second, if a weight has MICRO, but also has the metric designation instead of the english designation twice, you're going to lose points (except maybe for some of the very small, 1/2 oz weights).
                  Gary
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Re: Now, the number make sense.
                    Gary, Patrick,
                    I believe these are genuine? One is 1.25 and the other is 1/2.
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      Yes; the wings say the top one is correct vintage *NM*
