66 Electrical - NCRS Discussion Boards
66 Electrical
  • John F.
    • July 31, 1999
    • 105
    66 Electrical
    This may be simple but I'm a rank amateur when it comes to electrical. Recently my left hand turn signal stopped working. The ligt comes on but doesn't flash. I knew enought to check the bulb - OK, and the flasher - OK. I've checked the connections to the light and they seem OK. Grounds are all solidly attached. Only thing else I can think of is the turn signal unit itself. any suggestions?
    John Farren
    Re: 66 Electrical
    Have you checked to see if the bright filaments are working in both the front AND rear lamps? Frequently if one filament dies, the circuit doesn't draw enough current to cycle the flasher. The right turn signal lamps work OK?
