1958 Help Please! 2nd Request - NCRS Discussion Boards
  • Dick W.
    • 10483
    I am installing the dash pads on a 58. I need someone to post a photo of how the end cap is installed. Thanks in advance
    Dick
    Dick Whittington
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: 1958 Help Please! 2nd Request
    Dick...
    My advice,is to locate a '58 that you can actually look at the dash end caps...reason is you need to see how the dash pad material was folded; this is key for a proper installation (including the caps for 59 - 62) Once you see the materel folds, the two screw locations and mounting will be easy. If you still have the screw location holes will help also...
    Good Luck
    • Dick W.
      • 10483
      Screw locations are one of the problems. I was also looking for the folds
      Dick Whittington
