j-56 part # ????? - NCRS Discussion Boards
j-56 part # ?????
  • Joseph S.
    Infrequent User
    • January 1, 1988
    • 19
    j-56 part # ?????
    i just found a pair of j-56 ??? dual pin calipers with casting part # 64322276 and what looks like a date code of 18k4. does any body know what these are for???? thanks joe
    Re: j-56 part # ?????
    Joe-----
    There never was any caliper casting number of "64322276". However, I suspect that the number is actually 5452273. This casting was used for the front, outer caliper half from mid-1967 through about 1972 or, possibly, early 1973. The same casting was used for BOTH standard brakes and J-56. For J-56 front caliper halves the pin boss was machined off and the end holes were added for the cotter pins. ANY standard brake caliper half can be easily modified to be a J-56 half by doing exactly what Delco-Moraine did years ago. A caliper so-modified may be absolutely indistinguishable from an original J-56.
