without the drippers the oil stream would
shoot over top of the pivot point were the oil was needed. the drippers would make sure the oil got to the rocker balls. early on we welded deflectors to the top of the rocker arms over top of the oil hole to make sure the oil went directly to the rocker ball. we were able to use stock BBC rocker arms while using edge orifice lifters using this set up. without the edge orifice lifters too much oil was getting into the top end and taking too long to return to the pan
